I’ve been using the file manager without problems all along.
All of a sudden it is unable to save files. I see that I have been logged out yet relogging in throws “…could not read line from socket…” error.
Please Help me
How to fix that issue ? What’s the cause of the issue?
thankyou Sir
Looks like we are getting this error too now.
Me too but I did just relogin and clear the cache and done, works fine now.
Me too. I already tried several browsers and cleared the cache, but it isn’t working.
Oxy
May 28, 2020, 8:14pm
6
monstaFTP from CA seems to have a problem (outage, DDoS or some server work)
so in the meantime try using this one (also official)
https://mftp.infinityfree.net/
I have the same problem. But with Filezilla is possible the connect. Why? what’s the difference ??
yai i did but my issue still not solve
Hello, this is probably related to this issue as the File Manager relies on FTP. Normally, if the file manager gives you the error “cannot read line from socket”, it can’t connect to the FTP server.
Since around 15:45 UTC today, we’re experiencing an outage on the free hosting platform.
Some accounts are affected by this issue. If your website is affected, you’ll see errors like:
The connection has timed out
Error 522 - Connection Timed Out
ERR_CONNECTION_TIMED_OUT
FTP access also seems to be down for these accounts and, by extension, the file managers too.
As far as I can tell, you’re affected by this issue if your website is hosted one of the following IP addresses:
185.27.134.221
1…
