Cookies Not Enabled Error
https://mahaneyvoice.com/
It appears your browser is not accepting cookies, please enable cookies to continue to this page, or disable ‘private’ web browsing mode.
Instructions to enable cookies for all browsers can be found HERE
I have cookies enabled, and if I go to https://mahaneyvoice.com/index.php it works
Does mahaneyvoice.com go through Cloudflare, or any other CDN or caching service? And does the error still show in a private window, or on a different network such as your phone’s mobile data?
A similar topic had the same symptom: the error appeared on the bare domain, but the site loaded fine when the file name was added.
That poster eventually found that Cloudflare was serving a cached copy of the error page. Purging Cloudflare’s cache fixed it. Your case looks like that one, since /index.php works and the bare domain doesn’t. But that topic only resembles yours, and nothing yet shows it’s the same cause. The answers to those two questions should help tell whether it is.
Here is the topic with that fix:
I have now turned Cloudflare’s proxy OFF, so the domain is no longer proxied. After doing that, the root domain is still being intercepted by the InfinityFree cookie‑challenge page. The page being served is coming directly from the origin server:
http://sv101.ifastnet.com/cookies.html
/index.php loads normally, but the root path / is still blocked. This means the SV101 cookie‑challenge filter is stuck ON and is intercepting the homepage before .htaccess or PHP can run.
Cloudflare is not serving a cached page anymore. This is now an origin‑side issue on SV101.
Cloudflare proxy is currently ON again, but the issue persists exactly the same. The root domain mahaneyvoice.com is still being intercepted by the InfinityFree cookie‑challenge page. The page being served is coming directly from the origin server:
Code
/index.php loads normally, but the root path / is blocked every time. This means the SV101 cookie‑challenge filter is still stuck ON and is intercepting the homepage before .htaccess or PHP can run.
I have already:
  • Purged Cloudflare cache
  • Tested with Cloudflare proxy OFF
  • Verified that /index.php works
  • Verified that / consistently shows the cookie page
  • Confirmed the cookie page is being served by SV101, not Cloudflare
Cloudflare is not the cause. The origin server on SV101 is still returning the cookie‑challenge page for the root path.
Please reset the security filter for my account or migrate my hosting account off SV101 so the root path can load correctly again.
No issue on my end:
I tried using the trailing slash, visiting the base domain, and browsing through other pages on your site. No matter what, I can’t replicate the issue.
Could you please try clearing your browser cache? And if it still doesn’t work, try using a different web browser and/or a different device such as your phone.
The browser security system is not something that there’s specific controls for. And your hosting account isn’t being served from “SV101”, the cookie error page is. You’re only being redirected to it because your browser is failing to pass the invisible cookie challenge for some reason.
Thanks for checking it. The issue is intermittent and user‑agent dependent, which is why you may not see it. Firefox loads the site normally for me, but Chrome and Edge still get redirected to:
Code
This happens even after clearing all site data, cookies, cached redirects, and testing on multiple devices and networks.
Because the cookie‑challenge page is served before my hosting account is reached, this appears to be the front‑end security layer blocking the root path / for certain user agents. /index.php always loads correctly, which confirms the hosting account itself is fine.
Could you escalate this so the security filter can be reset? The root path is still being intercepted for Chrome/Edge even though Firefox loads it normally.
Opening your site in Edge still works fine with no problems.
I’m not sure what the exact cause is at this point, but I know if it were a server side issue (which has happened in the past) it would most certainly be a more wide-spread problem. In which case there would be many posts from other people experiencing the same issue with their sites.
No, I’m just another InfinityFree customer like yourself. When Admin sees this thread he can escalate the issue, if he deems it necessary.
The security filter cannot be reset. It’s stateless, there is nothing to reset.
It checks whether you have the security cookie. If not, it presents the challenge and redirects you to the URL with ?i=1 added to it. If ?i=1 is already present, it increments the counter. If the counter hits ?i=3, the server gives up and sends you to the cookie page.
The system doesn’t record who has accessed it and what they did.
If you want to try again, just access the page again. The server doesn’t remember, you’ll get the same three attempts again.
But if that doesn’t work, clearly your browser is not sending the expected cookie.
It’s enabled again now though.
Note that changing the Cloudflare proxy means a DNS change, which means it can take some time to take effect. Cloudflare specifies that clients should cache results for 5 minutes, so that’s the minimum time you can expect a change to take. But clients ultimately determine how long they actually keep the cache, which could be much longer than that.
