Urgent: Access Issue on eletricistaefaztudo.sampa.br - "Cookies not enabled" Message
Cookies are not enabled.
It appears your browser is not accepting cookies, please enable cookies to continue to this page, or disable ‘private’ web browsing mode.
Instructions to enable cookies for all browsers can be found HERE
Dear Support Team,
I’m writing to you about a critical issue preventing my customers from accessing my website, eletricistaefaztudo.sampa.br.
When users type just the main domain (eletricistaefaztudo.sampa.br) into common browsers, they’re redirected to an error page displaying the message “Cookies are not enabled.” However, the website loads perfectly fine when the index.html file is explicitly specified (eletricistaefaztudo.sampa.br/index.html).
This behavior is very concerning, as the vast majority of my customers access the site by simply typing the domain, using default browser settings.
I’ve performed extensive tests to isolate the cause and confirm that the issue isn’t on the client side or related to browser configurations. I’ve tested access using:
  • Google Chrome (my customers’ primary browser)
  • Other browsers (Firefox, Edge, etc.)
  • Incognito/private mode in all tested browsers
  • Different devices (mobile phones and other computers)
In all these tests, the result was consistent: the cookie error message appeared when accessing only the domain, while the site functioned normally when index.html was specified.
I’ve attached a video to this email demonstrating the behavior.
I suspect the problem might be related to the web server’s configuration for the default file (DirectoryIndex) or a script running in the domain’s root before index.html is even loaded. I’ve already tried adjusting the .htaccess file with the DirectoryIndex index.html directive, but the issue persists, suggesting it might be a higher-level server configuration or a script I’m not seeing.
Could you please urgently investigate the server configurations for my domain (eletricistaefaztudo.sampa.br) to ensure index.html loads automatically as the main page when the domain is accessed directly?
Thank you immensely for your attention to this matter. I look forward to your prompt assistance.
Sincerely,
Cassio Rodrigues, site owner.
See the problem in this video.
Great news! I’m happy to report that the website access issue has been resolved.
Solution Found: Cloudflare Cache Purge
As previously discussed, users were encountering a “Cookies are not enabled” message when trying to access my main domain directly. After further testing, I found that the problem disappeared when Cloudflare was put into “Development Mode.”
This crucial clue led to the solution: purging the entire cache within Cloudflare’s settings. This action forced Cloudflare to fetch the latest versions of my files directly from the origin server, eliminating the cookie error page.
I apologize for any inconvenience this issue may have caused you and my customers.
I’ll keep both the previous and current posts, detailing the solution, as I believe this information can be highly valuable to the user community facing similar issues with server configurations and CDN services like Cloudflare.
Thank you so much for your attention and assistance in diagnosing this problem.
