Other Information:
Constantly get this same message ( twice in 48 hours).
I can’t do nothing anymore to upload 3 images for example and do maintenance website at the same time, without getting suspended immediately.! Even if I do almost nothing heavy on my website. Still use the same plugins as before and never got problems before; till now!
Plugins I use with WordPress before this error appeared are easy ssl and image crop and regenerate
Like a sayed. I did not make any request to a PHP script , neither did a juse the corn job or what so ever. Maintaince a website is a normal thing to do. If you can not do this anymore a webhost is worthless!
Please send a picture of your plugins and theme from your admin dashboard. Are any of the plugins too heavy for a normal website? WordPress has many light weight alternatives
I used the same password for Ftp that I 've been given in the client area, but I can not connect. . The client area says unavailable to get to the File manager Panel! See also screen above in timeline.
Yes it is. Like a said before due to Entry Process Limits and that seems to be the problem, because this happened twice in 48 hours, without doing more other than maintaince website and upload 3 images! That was never a problem before , but it is now! If this issue happens again and again if I do a normal maintaince, it will be impossible to have a website!
You can’t access FTP because your site is suspended, and you can’t give us a list of plugins because you cannot access your website.
Once the suspension is over, login to FTP (Not your website) and screenshot the plugins directory.
Looking at your past suspension log, and the fact that you have not been suspended before, my guess that that more bots are visiting your website now. I would recommend Cloudflare, but you need a custom domain for that.
Today is the third time in a row that my account is suspended due to Entry Process Limits without diong much with my website. Today I only created 1 new menu post page. And guess what, before I was suspended for third time , I checked statistics and now were going to the rare thing : In the same time my account and website were suspended the statistics still show high enter process Limits? This should be impossible for a site and account that is down!! This means it is for sure a problem that lies with inifity and not with me!!!
Or… the graph in the control panel is in a different time zone. The client area is all in UTC, the hosting platform internally is generally in EST, so it would make sense that the days in the graph are rotated at midnight EST, not midnight UTC.
In UTC, the previous suspension was from 23:15 to 23:15, so the day in between would be completely gone. But in EST, this suspension is from 18:15 to 18:15, which still leaves plenty of hours to generate high server usage.
