Connecting MySQL to infinityfree
My first attempt at setting up a cloud-based DB, having trouble getting the connection established through MySQL?
I gave it a connection name, copied & pasted the “hostname”, “username” & saved the password in the vault. I left the port as 3306.
error message is pretty non-specific
“Failed to connect to MySQL at sql102.infinityfree.com:3306 with user if0_38150858”
“unable to connect to sql102.infinityfree.com:3306”
I am using MySQL version “MySQL Workbench 8.0.40 Community”
Read this:
ok, thanks
