Hi, I’m having an issue with my Cloudfare SSL who doesn’t work and I think it’s because of the DNS configuration.
My website URL is: lastlife.ml
What I’m seeing is: that the certificate isn’t valid.
I’m using this software: Xenforo, a forum CMS
Do I need to send you the DNS configuration of my cloudfare ? Thanks.
You also need to change the nameservers to Cloudflare ones from your domain registrar’s nameservers management panel if you want to use Cloudflare with your DNS configuration!
But my site won’t work if I do this.
It will work just if the Cloudflare thing that shows “Error 1016: Origin DNS error” gets fixed.
It may fix automatically just after the domain is renewed.
I don’t understand, I need to wait until the domain isn’t valid to buy it again ?
InfinityFree’s admin may need to renew epizy.com , because he owns it. You don’t absolutely need to do anything until it’s fixed, then you can change to Cloudflare nameservers.
I just need to wait until that domain is renewed by the owner ? Right ?
Okay thank you, I’ll wait, can the admin report in if he renews the domain ? Thanks.
Recently the Admin posted something about this:
Since roughly 13:00 UTC today, we have recorded errors in the DNS resolution for epizy.com .
Subdomains of epizy.com are unreachable
With epizy.com itself being unreachable, all free subdomains of epizy.com are unreachable as well. There is sadly no workaround for this.
If you do need your website to be reachable urgently, you can of course create an additional subdomain for your hosting using another domain name. You can do so through the Subdomains section in your control panel.
Effects on c…
