Changing Nameserver to infinityfree
I want to change my DNS nameserver on register.it domian provider .
I put ns1.infinityfree.com and ns2.infinityfree.com but also wants me IP address of these Nameservers so i put 198.251.90.216 , 198.251.86.153 but support of register.it told me your Nameserver is invalid .
what should i do ?
ialso I try to put alternative Nameservers ns3.byet dot org → 198.251.86.154 , ns5.byet dot org → 198.251.86.152 but still dosen’t work.
Hi and welcome to the forum! Please read the Knowledge Base next time before posting, as you can find most of the solutions there.
I added my domain with CNAME to the infinityfree but still i need to change my DNS nameserver to the infinityfree Nameservers.
first do name server from like ns1.example.com, ns2.example.com to ns1.infinityfree.com and ns2.infinityfree.com then change it back to any NS like cloudflare make sure you see the A records pointing to infinity free servers like A record could be this 1.1.1.1 make sure that IP matches the one in your hosting account
Simply do the following:
  1. Add the required CNAME record for the CNAME verification to your domain’s current nameservers.
  2. Add the domain name to your hosting account.
  3. Change the nameservers of your domain name to our nameservers.
When the domain name is added on our end, your registrar should have no problem letting you use our nameservers.
i changed my Nameservers to the Cloudflare Nameservers after that what should i do?
what is my IP address?
Go to your domain on Cloudflare, then go to DNS and make a new A record pointing the IP from your hosting account to CLOUDFLARE
image you can find that in your hosting account Note all IP address are different
To get your IP, if you don’t know it, go to your hosting account in the client area in the home tab, which says account details. Scroll down until you find a label that says website IP. Copy that IP into CLOUDFLARE like this
Replace subdomainname with your desired subdomain, like sub.example.com, and for the root domain, like example.com domain, put @ where it says subdomain name. Replaceip_example: _ 185.27.134.170170 with your hosting address
Hi im trying to take my domain from namecheap and bring it here but nameservers doesnt work there and i got this message to them Namecheap team : Thanks for waiting. Denic (.DE Registry) has certain requirements for nameservers that can be applied to .DE domains. A minimum of 2 authoritative independent DNS servers are required. It means that the IP addresses of each nameserver should differ by at least one number in any octet. Also, at least one of them must be connected via IPv4.
If you want to use your own DNS, you must enter two nameservers where the IPs are not the same. Otherwise, the .DE registry will not allow the change.
can someone tell me what to do or how to bring it here thanks
This whole topic covers this exact issue (different extension but same issue). Please read the posts above and apply the instructions provided.
