main domain : oih0wnh9.epizy.com
my website : biznusss-solutions.epizy.com
Ip address: 185.27.134.225
i accidently changed http to https and now my website and admin panel is gone, i cannot even access to wordpress settings to restore the settings. screen says error 500 when i try to open my website.
please restore my website
KangJL
July 20, 2022, 3:42pm
2
This should help.
Read carefully
WordPress is a great and very popular website building tool, and Cloudflare is a great way to get HTTPS on your website for free. Thanks to Cloudflare’s Flexible SSL system, you don’t even need to manage SSL certificates to use it!
However, getting WordPress to show a padlock and make all pages work can be a bit tricky. This article explains a good way to configure your website correctly with Cloudflare Flexible SSL.
Heads up! Instead of making WordPress work with Flexible SSL, you can also c…
but i cannot get into my website wordpress admin panel how to restore my website to http
i checked my wordpress installation is gone as well and there isn’t any database in phpmyadmin
KangJL
July 20, 2022, 4:07pm
6
See if this is applicable
WordPress needs a database to work, so if you have a WordPress site, you must have a database as well.
However, there is currently a bug in the system. If you install a script with Softaculous, a database is created, but this database doesn’t show up in the MySQL Databases and phpMyAdmin sections in the control panel. To make the database appear, you can find the database name in the installation details in Softaculous, and then use the MySQL Databases section in the control panel to “create” a…
