How can my website have generated over 50,000 hits if Google’s monitoring shows only 3 or 4 clicks per day, and the site is configured to track all activity? In organic search, our website has appeared as a suggestion from the system itself 250 to 300 times a day. I can send the access graphs. The site’s structure is HTML5 and does not contain Java objects. I am available to correct any inconvenience I may have unintentionally caused. I await your instructions.
Please understand that this is an English forum. I’ve translated your message for you.
The hits are very different that any of the metrics you could monitor with analytics tools. In the worst case scenario a poorly built website could use up all 50000 hits in one page view.
Besides, one can not really configure an analytics tool to “monitor all traffic”. Ad blockers exists and those usually blocks analytics as well. There’re also bots which do not trigger data aggregation at all.
Clicks Are Not equal To Website CPU and Database Usage, Google Analytics Only shows How many users searched and clicked on your website, But infinityfree counts every network request made to it HTTP and Database, if you think you don’t use enough CPU and Database, check if anyone wantedly making request to your website a (D)DOS.
If you really use CPU and Database Please Upgrade Plan
First of all, I apologize for using my native language (Brazilian Portuguese).
But I have a few considerations:
As far as my knowledge allows me to see, my website is built on HTML5. I don’t have any databases running on it because it’s a static website, and the only possible interaction is sending it to WhatsApp, the client’s email, or the client’s phone number. My site doesn’t collect any data. I have no idea where these CPU usage requests are coming from. This has never happened to me before. I don’t know how to find the source of the problem. Could someone help me with this investigation?
I appreciate any instructions and insights to resolve this unfortunate situation.
WebburnsTech_Admin is new here. I didn’t wanted to harrass people who are trying to help so I didn’t say it but since you asked no what he posted is not really related to your issue. You are hitting the hits limit, NOT the CPU limit, database limit, or whatever limit there be.
You are hitting, and only hitting, the HITS LIMIT. We should only discuss this specific limit.
Hits limit could easily be reached on a poorly optimized website. Bots and attacks could also easily generate enough traffic that is invisible to analytics tools.
Unfortunately free hosting don’t keep access logs, neither does this forum provide any kind of one on one support because it’s a community forum, so you must try and figure out if your page is using too much assets to load a single page.
You can also use CloudflareONLY if you have a custom domain to help mitigate the bots issue.
I have the same issue. Suspended for too many “hits”..yet only a few people have looked at the site, which is about 5 jpgs and 2 embedded videos. So, 24 hr suspension, then the minute that’s over, another notice regarding “abuse” and a suggestion to upgrade from free.
I asked tech support if this might have been a theft of service attack, again, their response was to upgrade to keep using the site. Is this a tactic used to get users to upgrade? Is this common here?
Unfortunately ddos attacks do happen from time to time. And they can result in suspensions, since the traffic still uses resources and impacts other sites, not just yours. It’s not ideal but it does happen.
I’ve been using free hosting for 18 months now and can confirm it is legitimate.
To protect yourself from ddos id recommend getting a custom domain (like a free .pp.ua one) and using cloudflare
Before I left Infinity Free for paid hosting, I was able to cause this same problem by making an error in my .htaccess file. When I asked the Brave Search AI “Is there anything in this code that could cause 50,000 hits in a short time span?,” it answered yes, told me how it could do so, and recommended a fix that seems to have worked.
