Is it even possible to install iOS on an Android device? I actually like using Android, I was just curious. By the way, what is your favorite Android version?
samsung galaxy s7 bomb :joy:
I don’t really have one. I just use whichever one is on the phone I’ve got haha
Do you have a favourite one?
I actually use whatever I have on hand too, but if you ask me what my favorite is, I’d say Android 12, 13, or 14. Android has added a lot of features recently. Android 16 looks nice, but it felt a bit too complex to me.
Don’t get me wrong, Android 16 isn’t bad, it’s just a bit too complex for my liking.
Really old iPhoneOS yes, anything newer no, but if you consider QEMU then we could go much higher, there’s a QEMU fork which allows you to run iOS. But it’s a tedious process to install because iOS does not come with any “install” media, only full restore images.
iOS 27 is coming out very soon, but I’m staying on iOS 18 because I don’t like liquid glass I don’t want to lose my ability to freely enable JIT without some sort of scripts
Although I recently got some devices that have iOS 6/7/810 on it (I f*cked up the iOS 8.4.1 install on the 5s so I had to restore it to iOS 10.3.3) :laughing: :sob:
Apparently Cloudflare only allows you to add 200 DNS entries with a free plan now, may be this is the case before already but I’m still a bit surprised to see this
thats plenty for personal project so it isnt a big deal for most of us (i assume)
It’s more than plenty for free domains, yea.
But my hosting account
But my hosting account with gazillion (read: 13) custom domains (because i’m apparently rich for some reason) and some of those domains were expired and i didn’t renew, and all of them were mostly empty sites was suspended for entry process limit. Sure², i want to really test how many times an account gets suspended before terminated for good, but is this too much suspension for average user?
DeepSeek releases a new model that supports image recognition so as someone who have a DeepSeek connector on the WordPress plugin directory I know I have to update it, so I could also benefit from it, right?
Turns out WordPress doesn’t give you the option to generate alt text completely while using the classic editor. Only when you use the block editor they give you the option, in the exact same media selector interface classic editor uses…
Wow WordPress that’s a brilliant way to turn users away from the good old editor :expressionless:
I might have to purge records at some point…
Same!
I shall stay with Windows 10, despite the risks and Microslop breaking it slowly themselves.
I may not be a Regular here, but we’re definitely a Regular in Life.
Be careful with where you go on Discord. Saying “We” in place of “I” will automatically classify you as a robot.
Take an old Chromebook, Flash it, throw Ubuntu on it, setup a Weather Channel, and throw it in a closet. News station around here’s not holding up as long as they usually do, so this works out.
Pandora Plus is worth it. When the heck is Pandora Radio expanding into other regional markets? Likely Never. Cloudflare Zero Trust will help you out though.
Life called. They want me to keep working on a WordPress website. See ya!
ESU is free for everyone if you have a Microsoft account, don’t take the risk :wink:
I hate how you need a Microsoft account just to use windows nowadays. Luckily I got a local account before they removed it on windows 11…
Genuinely annoying how I can’t select text on mobile all of a sudden? Is my phone just stupid or what, guess I’ll have to edit my message in a few minutes
Unless you don’t have an ad blocker or click every link then I’m pretty sure you won’t easily catch a virus.
They’ve broken the C drive, recycle bin, heck even the calculator. I’m sure they’ll find something new that everyone uses to break
To be honest, I am on Windows 11, but I haven’t updated in so long that I’m probably on a year old Insider build by now. But if I do update it’ll probably break all my custom theming (i’ve modded to make everything I can windows 10 styled, yes it’s lame but I can’t downgrade to 10 for now)
They might nag you to add one someday when you login :wink:
But whatever, I login to Microsoft account to Windows.
I do create a local account first, then login into Microsoft Edge. This creates a “hybrid” account which keeps all local account features while stops Windows from annoying you. Like best of both worlds.
They made that change a few months back (might be around a year ago now). Thankfully legacy accounts kept the 1,000 limit.
Legacy domains I think. I definitely have a legacy account, and after you said this I checked, only my old domains have the 1,000 limit.
Apple started to soft ban free developer accounts, guess Apple really doesn’t want people to sideload on iOS :confused:
I’m pretty sure that either breaks a law here or I can just taskkill the oobe/Microsoft account service. Pretty sure I’m still on 25h1 or something I’ll have to check
What do you need 1000 DNS entries for tho? It’s a lot
Just get an old android (think like 7.1.1 to 12 or something, they’ll lock down newer android versions soon), degoogle it and you have a brick that lasts 2 weeks on a full charge
“Still” on 25H1 and it’s like the first version where everything started to go very wrong
But on second thought I don’t think there’s 25H1 at all, maybe you mean 25H2?
Ah, so you are from EU? That makes sense
No thanks, I’ll rather get an iPhone that runs iOS 15 or something
I still have yet to check
Look at my username it’s right there lol
I never thought in this direction :face_with_tongue: EU Windows is pretty much a different OS than regular Windows, although Chinese Windows is even more bizarre
