Those IPs weren’t on PHP 8.2, but were still on PHP 7.4… Now the sessions on some of them (if not most) are broken!
Follow-up just to say the websites on those IPs went back to normal, so I think I thought well about the servers being upgraded…
Now we’ve got other two IPs to the list of the ones maybe being upgraded! They are .165 and .214!
Here is a screenshot of minified aes.js which is served
Woo hoo :joy: we are progressing !
btw. still not gzip/brotli
This is more eye straining than when trying to view an exe file on x64dbg as an assembly beginner.
The picture is not really for viewing, but more for the archive.
10k and 20k topics are like a diary of all events on hosting so I decided to mention that too.
For approx 10-15 hours we are on the new version of the forum
Summary
New Features
  • Add Revise… option for queued post reviewable (23454)
  • Allow searching users using a list of usernames (23902)
  • Option to automatically delete unused tags (23864)
  • Granular webhooks (23070 )
  • Remove support for legacy navigation menu (23752)
  • Delete multiple inactive themes/components (23788)
  • Introduce api.renderInOutlet (23719)
  • Support a description attribute on form template fields (23744)
  • Add API key scopes for tag_groups (23634)
  • Add custom date range filter for admin dashboard reports (23702 )
  • Add prompt=none functionality to SSO Provider protocol (22393)
  • Add webhooks for user suspend and unsuspend (23684)
  • Improve error message when double liking (23698)
  • Allow filtering posts report by multiple categories (23669)
  • Link chat notifications directly to message (23617)
  • Site settings to revoke api keys older than a number of days (23595)
  • Add outgoing web hooks for Chat messages
  • Add chat message notifications for personal chats (23307)
Bug Fixes
  • Open invite modal correctly from topic share UI (23940)
  • Add missing type to form template upload (23935)
  • Transitioning to tag-intersection route (23931)
  • Revert (edited) layout in chat message (23927)
  • Pass category param on /tags/intersection (23352)
  • Chat layout shift with GitHub onebox (23909)
  • Ensure nested ember components can be used with mustache syntax (23912)
  • Support PluginOutlet invocations with deprecated tagName (23913)
  • Ensures threads list button is not showing (23895)
  • Correctly untrack topics when dismiss unread (23894)
  • Prevent browser refresh when clicking search menu result (23881)
  • List parent/child tags correctly for categories restricted to tag groups (23708)
  • Remove border-radius from thread list item (23878)
  • Disable overflow-anchor on composer textarea (23875)
  • Update upload security on post rebake from UI (23861)
  • Display error when moving post fails (23860)
  • Minor chat styleguide fixes (23849)
  • Hide consolidated chat message notifications temporarily (23846)
  • Fetch csrf token if needed before uploading (23825)
  • Correctly reset active message on destroy (23844)
  • Uses correct label on mobile view for members (23845)
  • Properly create a mention when followed by dots (23829)
  • Handle thread participants limit on the frontend (23839)
  • Multiple delete themes spec fail in parallel (23837)
  • Always use the current session token in uppy (23812)
  • Embroider breaking index html structure (23811)
  • Correctly checks user activation on use (23793)
  • Long press chat message test failure (23791)
  • Call UserBadge.grant with badgeReason in admin interface (23753)
  • Don’t nest all user info in one link (23783)
  • Ensures close arg from d-menu/:content works (23773)
  • Allow category moderators to move topics to their categories (20896)
  • Use correct subfolder format for ember-cli config (23754)
  • Pass email correctly when resending activation email (23741)
  • Remove reference to removed site setting from num_users_to_silence_new_user setting (23718)
  • Make CookText component reactive (23709)
  • Keep bookmark modal open when using keyboard (23707)
  • Correctly clear the quote state (23705)
  • Allow history modal columns to shrink width (23700)
  • A regression in RequestGroupMembershipForm (23699)
  • Disallow moderators from custom public sidebar sections (23683)
  • Copy button JS test failures (23687)
  • Broken error reporting in modals (and other places) (23680)
  • Copy codeblocks needs client: true (23686)
  • Correct error on add user modal (23679)
  • Enable copy code block by default (23662)
  • Correctly sort channels with null last message (23672)
  • Ensures we reuse existing thread if existing (23618)
  • Custom sidebar section link with / path leading to blank page (23661)
  • Ensures an empty last message won’t cause errors (23647)
  • Parse the digest_suppress_tags setting correctly (23623)
  • Use the destination_url cookie as return_path if present (23594)
  • Add back missing ‘delete spammer’ flag option (23605)
  • Message date is incorrect when replying as new thread (23608)
  • Return 403 instead of redirect on username routes when hiding profiles (23545)
  • Discourse-local-dates mobile layout following 8a577984 (23564)
  • Scope animated-images-pause to topic-post (23561)
  • Prevent lightbox images from double escaping titles (23458)
  • Min_personal_message_post_length not applying to first post (23531)
UX Changes
  • Better align user count (23941)
  • Improves reminder setting text (23918)
  • Fix likes notification for multiple users on mobile (23896)
  • Opens thread on channel with unread threads (23361)
  • Keep form template client state when shrinking/reopening the composer (23858)
  • Prevent (edited) and following from being copied (23882)
  • Composer and sidebar better fit (23841)
  • Correct description on ‘create topic’ composer dropdown (23871)
  • Place (edited) on same line (23866)
  • Makes avatar non interactive in thread participants list (23847)
  • Redesigned settings/members (23804)
  • Thread list fixes for alignment and more spacing on mobile (23823)
  • Flat design for thread list (23821 )
  • Keep timestamp on single line (23819)
  • Remove excerpt + style change to thread list item (23776)
  • Prevent unexpected preview scroll in Firefox when using grid (23777)
  • Center loading spinner for editing nav menu tags modal (23786)
  • Enhances chat copy features (23770)
  • Update ‘gtm_container_id’ site setting description (23763)
  • Removes username from bookmark notification (23760)
  • More topics mobile spacing (23745)
  • Focused spacing in more topics table (23730)
  • Selected indicator more topics spacing (23696)
  • Improve history modal layout (23675)
  • Restore wizard confetti in final step (23533)
  • Correct tab selection in Wizard styling preview (23639)
  • Improve activity column title data (23614)
  • Unhide experimental_form_templates (23615)
  • Only close modal for full ‘click’ events outside (23566)
  • Fix “More” menu at small tablet width (23616)
  • Fix overflow channel row + mobile remove styling tweak (23611)
  • Chat-channel-row alignment (23607)
  • Creates a vertical space between the title and the back link (23558)
  • Improves remove channel animation (23585)
  • Removes a duplicate modal footer. (23226)
  • Hide warning if all users mentioned via group are already invited. (23557)
Accessibility
  • Move new account disclaimer above buttons (23884)
  • Remove positive tabindex from create modal (23883)
  • Improve summary page user link structure (23746)
  • Composer tip close link should be a button (23731)
  • Improve small-post markup for screen readers (23732)
  • Fix keyboard nav for custom bookmark time (23710)
  • Improve about page profile link markup (23695)
  • Correctly markup /about stat table headers, tweak style (23733)
  • Remove title from notification menu icons (23735)
  • Add page title to account activation step (23736)
  • Improve contrast on the WCAG color schemes (23692)
  • Add aria-label to share copy button (23706)
  • UI emoji are decorative, use alt="" (23690)
  • Add aria-current to active navigation item (23691)
  • Aria-label for mobile topic list avatar (23693)
  • “more” nav link should use aria-expanded (23613)
  • Disable non-essential CSS animations for reduced-motion users (23571)
  • Activate user menu tab on keydown too (23593)
  • Avatar upload button should be focusable (23575)
  • Add focus state for advanced search button (23573)
Finally, an update that hasn’t radically changed the look and feel of the forum!
Let’s go! :rocket:
Next stop: CNAME Records (some have been reported to function once again)
What happened to gzip? Or do you mean the files aren’t gzipped?
Looks like yes
aes.js issue again
Apparently 40% of this entire hosting is having problems. So sad
I don’t know how much this is interconnected
but it is quite glowing on a DDoS map
Super nice map, but looks like it’s far south than I thought. Is that where the affected IP are located?
I don’t know what the map shows at all and how geographically accurate it is ( maybe it simply marks the country)
btw. it no longer shines as it did
thank goodness :slight_smile:
Screenshot_92
@anon90933456 rip your test account too :confused:
Yeah, .112 is down!
I also saw the topic and all I gotta do is wait…
I changed the IP of my website this morning and these actions are slowly getting on my nerves because this is not the first time in 30 days
  • turn on worker on CF (maintenance message and 503 status)
  • change NS on domain to lead to epizy ns (confirm email pin and security questions)
  • remove the domain from the system
  • add it to another host acc
  • make a self signed cert
  • upload files (wait for FTP to work because it is crowded and there are too many users)
  • restore domain NS to previous values (Cloudflare ns)
  • change IP at CF
  • shut down the worker
  • test each page
:exploding_head:
I expected much more professionalism :joy:
Screenshot 2023-10-19 163901
I’m going to reply to the underlined parts:
US-based
Is TechRadar sure about that? :rofl:
Linux-based cPanel
A panel that looks like cPanel doesn’t mean it’s cPanel though…
it makes managing your site so much easier than a custom-built control panel
I’m going to repeat: is TechRadar sure about that?
Have they started writing articles with AI?
The hallucination in heavy with this one.
I also wanted to write some other responses to that TechRadar article:
Infinity Free
Well, well, well… Just write it properly! They wrote it right in some parts of the article, but then I want to comment on the parts where they left the name with the space!
it should include unlimited disk space
It’s 5 GB, not unlimited!
I think so, and I also think they left some older information on that article as well!
