Another follow-up just to say this:
@anon50163844, now every IP that was down is up again, so even my test website is up again!
We passed the figure of 5,000 tanks
Sorry for not commenting earlier
it is heard that you have made progress and that you are much more serious ![]()
Remember to export the project as a zip so that you have a kind of âmasterâ and save it somewhere as a backup.
Congrats to EdwardHamHam for attaining Regular status!!!
@anon54841129 congrats!
Thank you! ^w^
Welcome back to the Regular crew, @anon54841129!
Portable apps I use immediately closes right after opening it. filezilla, putty, vlc, you name it. How do i fix the problem?
Itâs been a while since I didnât use portable apps, so I donât know if I can help you⌠Maybe try to install a new version of them, or use the launcher that is provided with the portable app to launch the app? Maybe also rebooting should work?
i need to actually logoff instead of switch user. sorry for bothering you.
Are you connectinv to the same server?
Iâm late today
I had work today because I bought parts and assembled a new PC ![]()
This time I only have some similarities with @JxstErg1 jst because we have the same chipset ![]()
No matter how many times Iâve done it, itâs always super tense when the power button is pressed for the first time ![]()
I installed the sound driver twice ![]()
at first I thought I didnât connect the front and rear audio cables (case hd audio) properly
because no matter where I plug it in, I have no sound
and then, after everything, I go to the win11 settings and see that they put the sound card from the graphics card as default instead of the one from the motherboardâŚ
I was most afraid because the CPU doesnât have integrated graphics (itâs cheaper and I donât need it), but since I put a newer processor inside, I wasnât sure if they put the latest BIOS update to support that CPU, and then I think what if I canât see the bios because there is no video signal etcâŚif the CPU is not supported etcâŚ
But luckily it went without any problems ![]()
later flashed the bios to the latest version, OC RAM to work at its clock, etcâŚ
Tomorrow move all images from SYS partitions to M2
, and then once Win11 23H2 comes out, Iâll probably do a clean install to get rid of the crap from the ex pc
first i was thinking of getting ryzen-7-5800x
but saw online that it is an older processor that consumes 140w
and mine is newer with slightly weaker characteristics and only 65w
in addition, when you OC, it is stronger than that one⌠for me it is now at 4.2Ghz
But not the same motherboard! At least ASRock is a good brand as well ![]()
Yeah⌠But when you get good parts, when you turn it on you can simply scream, âIt works! Yesssss!â as everything turns on! Another satisfaction is when you get to see the first POST⌠But then⌠Coming nextâŚ
I also have the audio driver from my graphics card, but decided to plug in my headphones and when I selected the audio input it workedâŚ
My motherboard at least came with the BIOS update necessary to boot into the BIOS with my CPU installed (it was also a fairly decent revision, they shipped me the Rev1.4 of it, which came with BIOS 2.E I think), but in the box they still have the âAMD Ryzen 3000 Series Desktop Readyâ sticker on itâŚ
And this is the important part!
Oh, and you also got a cooler as the Ryzen 7 5700X really needs one⌠At least itâs not as power-hungry as the 5800X, so even that cooler works fine!
all kinds of dark scenarios were going through my head from the possible 3 beeps onwards
itâs always drama
I always take a huge cooler because you donât even need a fan unless you are extremely OC CPU - Iâm calmer and I donât have to think about whether the CPU is cooking or not.
itâs good that the motherboard supports even version 9 of the processor, so that once the prices drop for a few years, we can very easily and cheap upgrade the system
Super nice computer ![]()
My ex MB was also asrock
and they got my trust mostly because after 10 years since MB was produced, when those security flaws appeared in intel processors, etc., and after 10 years, they issued a BIOS update where they patched it with new microcode, etc.
and in general they are constantly working on new bios versionsâŚfor all types of motherboards from the cheapest to the premium ones.
Besides that, often when I read their support forums
I often come across cases where someone with a 12-year-old motherboard decides to buy a new GPU and the like, so he has some problem and they create a custom bios flash for him⌠and additionally remind him that if he changes the hardware in the future, he should return the bios fw to the default instead of use that custom.
Other companies would say: âyou have a 2 year old MB? buy a new pc⌠forget about our supportâŚâ
Thank you ![]()
When I see the âUFOâ classification I am satisfied ![]()
My current result with no cheats (like setting the disks to use RAM, I didnât turn off AV, etc.) - Asrock B550 Pro4 Performance Results - UserBenchmark
As long as the CPUs arenât iFastNetâs, because we already know the resultâŚ
At least Brave Browser on my MacBook still works!
Anyway Iâve found some new user I had to report three times total because of them being a badly-educated kid and whose username I donât have the right to say anywayâŚ
