XML RPC access problem with wordpress
I have problem while login into my wordpress blog from android apps. Its says XMLRPC access denied by server and endpoint not found. I want to ask some question.
  1. Did infinityfree block XMLRPC access?
  2. If not block how do I slove my problem.
    pleasea check my site http://eigiwari.in
We block all bot queries to our free hosting to protect your websites, but that does mean that certain things like uptime monitors won’t work. It’s likely that XMLRPC is being blocked. If that’s the case, I’m afraid you cannot use XMLRPC on our free hosting and you will have to upgrade your account to be able to use it.
