Xenforo Forum Critical Error
https://trytokill.me
The required PHP extension GD was found, but JPEG support is missing. Please ask your host to add support for JPEG images.
I’ve been running my forum for over 2 weeks+, this is the first time this has happened. Before you say Xenforo is paid and doesn’t perform well on free hosting, It is working perfectly, but this error just appeared. I am sure this has to do with the free hosting team (they might’ve removed support for JPEG.
May I know, where did you get this error? When trying to install Xenforo or when trying to upload a jpeg?
If when trying to upload an jpeg, could you just change its extension into an png or jpg files so that u know it will work.
I already installed Xenforo and the forum was completely working, users started registering, life was good until today. Well the error that I gave you was in the admin control panel, I will insert the error I get when I try to enter the page:
An exception occurred: [TypeError] Argument 3 passed to XF\Template\Templater::fnCssUrl() must be of the type array, string given in src/XF/Template/Templater.php on line 2170
  1. XF\Template\Templater->fnCssUrl()
  2. call_user_func_array() in src/XF/Template/Templater.php at line 922
  3. XF\Template\Templater->fn() in internal_data/code_cache/templates/l1/s6/public/helper_js_global.php at line 27
  4. XF\Template\Templater->{closure}() in src/XF/Template/Templater.php at line 701
  5. XF\Template\Templater->callMacro() in internal_data/code_cache/templates/l1/s6/public/PAGE_CONTAINER.php at line 2620
  6. XF\Template\Templater->{closure}() in src/XF/Template/Templater.php at line 1301
  7. XF\Template\Templater->renderTemplate() in src/XF/Pub/App.php at line 547
  8. XF\Pub\App->renderPageHtml() in src/XF/App.php at line 1988
  9. XF\App->renderPage() in src/XF/Mvc/Dispatcher.php at line 362
  10. XF\Mvc\Dispatcher->render() in src/XF/Mvc/Dispatcher.php at line 53
  11. XF\Mvc\Dispatcher->run() in src/XF/App.php at line 2177
  12. XF\App->run() in src/XF.php at line 390
  13. XF::runApp() in index.php at line 20
Seems like this is an server or hosting error.
XenForo System Requirements
  • PHP: 5.2.4+
  • MySQL: 5.0+
  • PHP extensions: MySQLi, GD (with JPEG support), PCRE, SPL, SimpleXML, DOM, JSON, iconv, ctype
  • PHP safe_mode off
