The 404 page currently shows https://errors.infinityfree.net/errors/404/ instead of the one in my (WP) site template.
Please let me know how to restore the correct 404 page.
Thanks in advance,
e.
Thanks in advance,
e.
You might need to set up custom permalinks so that WordPress also handles the HTTP errors for you as well; you can do that from your WordPress website settings or, if the WordPress website can’t create the .htaccess file needed for the permalinks to work because of some unknown reason, you might need to create it on your htdocs folder for your domain and add this on it:
# BEGIN WordPress
RewriteEngine On
RewriteRule .* - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
RewriteBase /
RewriteRule ^index\.php$ - [L]
RewriteRule . /index.php [L]
# END WordPress
Thanks @anon90933456, I think I can drive a htaccess.
