Takis_k
January 10, 2023, 12:21pm
1
I can’t access the admin panel on the website systemi.se . I get the “too many redirects”, yet I uninstalled the instance and the problem persists. Uninstalled plugins, themes yet situation remains. Cloudflare handles DNS.
KangJL
January 10, 2023, 12:48pm
2
We cannot help you if you do not provide more info.
What is the domain?
Takis_k
January 10, 2023, 12:58pm
4
Clean installed it again. SSL is creating the issue
If you are using Cloudflare SSL on WordPress, please read the below KB article:
WordPress is a great and very popular website building tool, and Cloudflare is a great way to get HTTPS on your website for free. Thanks to Cloudflare’s Flexible SSL system, you don’t even need to manage SSL certificates to use it!
However, getting WordPress to show a padlock and make all pages work can be a bit tricky. This article explains a good way to configure your website correctly with Cloudflare Flexible SSL.
Heads up! Instead of making WordPress work with Flexible SSL, you can also c…
Seems working for now probably due to a clean install. However, database connections seem a bit unstable. Getting errors on database errors / wp-config issues when I try to backup via updraft.
KangJL
January 10, 2023, 2:27pm
8
Takis_k:
backup via updraft.
This will not work well on free hosting.
The correct way to backup is below
Good website administration requires making backups of your account regularly and storing them somewhere safe yourself. You also need to download backups in order to migrate website to other hosting accounts.
InfinityFree does not create or store any backups of free hosting accounts. It’s your responsibility to regularly create backups, and to store them somewhere safely.
Backup your website files
The best way to backup your website files is by downloading them using a desktop FTP client.
O…
system
Closed
January 17, 2023, 2:28pm
9
