i finally installed WordPress after PHP issue but i unable to login in wp-admin when i fill password and username it just redirect me to homepage of site please hep
mine is doing the exact same thing. i think it have something to do with softtucus. something like that. it’s messed up atm
Admin
July 20, 2020, 5:18pm
3
What’s the URL to the website?
splash
July 21, 2020, 4:38am
5
It’s because your IP is suspended. Don’t fret, not InfinityFree account, (the one you use to sign in to InfinityFree) the one your website is on. (epiz_XXX)
Please look at this topic made by Admin.
Since July 19 around 23:00 UTC, the website IP 185.27.134.178 went down.
If your website is hosted on one of these IP addresses, you will see some kind of “Connection Timed Out” error on the website (the exact message varies by browser), for example:
The connection has timed out
Error 522 - Connection Timed Out
ERR_CONNECTION_TIMED_OUT
If you’re not sure which IP address your account is hosted on, you can find it under the Account Details panel in the client area .
I don’t know yet why these…
but i made my website 3 days ago
so whats the problm
looks like due to missing extensions due to upgrade, you’ve to wait till they fix the issue
Yes I am also facing this same problem
Admin
July 21, 2020, 9:33pm
9
Yes, @anon69086324 is also experiencing this problem. This is why I shared this possible solution in the other topic:
I checked your website @anon69086324 and I see you have the “Loginizer” plugin enabled. This plugin is intended to block potential attackers from logging in to your admin area, but could be locking you out too.
Please try disabling the plugin and see if that lets you login. You can disable the plugin without using wp-admin like this:
