I turned on a plugin, Elementor. And then everything freezes and it says " Site experiencing technical difficulties". I am not sure what to do.
I can enable other plugins and add without this problem. But when I just try to enable Elementor, it happens.
Try to force remove Elementor via FTP by connecting via Monsta FTP, going on htdocs/wp-content/plugins and removing the elementor folder. Then reinstall it again and try to enable it.
I’ve done that 3 times now. And it still shows the error.
Then install Elementor via FTP by going here and clicking on Download, extracting the zip file and uploading the elementor folder with a FTP client like FileZilla on htdocs/wp-content/plugins folder after doing the force removal steps of Elementor if it doesn’t work.
Same issue again.
This is the first time I’ve had problem with elementor because it works on my other website.
I found the issue, my Elementor pro plugin made so the normal Elementor broke.
