Hello everyone. I gust downlod my http://hr-solution.epizy.com/ site to free hosting and connect datebase). On frontend everithing is ok but when i trying to login there is mistake
" There has been a critical error on your website. Please check your site admin email"
Any ideas?
Thanks
Welcome!
I don’t see an error message on the main site, nor on the admin login page. Do you still get the error?
Yes. When i trying to login to admin there is still error
KangJL
November 22, 2022, 3:58pm
4
No issue
Clear your browser cache?
mistake appers when i submit login and password
KangJL
November 22, 2022, 5:51pm
7
My guess is website was broken due to WP update.
Try this
WordPress frequently releases updates, which you can install through WordPress’ admin interface. Usually, this works without a hitch. But with some (big) upgrades, the upgrade fails half way and leaves you with a broken website.
Fortunately, you can still fix your website without any data loss, and this article tells you how to do that.
Download a fresh copy of WordPress
First of all, you will need to download a fresh copy of WordPress. You can download this from the official WordPress website…
and remember to do this as well
Do you often see this on your WordPress website?
[image]
If so you may need to change some of the installation settings.
Installing WordPress
For
Fresh Installation
Make sure you are using the following settings when using Softaculous Install
[image]
Existing Installation
You can access your existing installation via
[image]
Followed by
[image]
Make sure these are the settings used
[image]
On the WordPress config
To play safe, add this line to the wp-config.php
[image]
