Will my site go live
Username (e.g. epiz_XXX) or Website
epiz_29148251
http://casadelosbatesforsale.rf.gd/
so I have created a new wordpress site for the first time - i have downloaded firezilla and transfered files from wordpress and sql - when i use the url above it brings me to a static page that has rainbow colours and an ad but doesnt have the qz at the end of the url or the error this site cant be reached,. this has been since approx 5pm 15th july i dont want to wait the full 72hr only to find i havent linked the site properly, thanks very much
No. The IP does not look right
Ok any idea what i need to do? thanks
What is that tool @KangJL ?
You need to add free subdomain to your hosting account.
for checking dns propagation
Link?
hi again, thanks for your help so far - i know im doing something wrong here -
anyway so i have added casadelosbatesforsale. as a subdomain but i think it may be that i have casadelosbatesforsale.as my domain but my wordress url is different and i have not done something correctly to link the host with the page…
casadelosbates557200509.wordpress.com
If you’re using a free subdomain, there is no “linking” you need to do. Linking the domain to the account happens automatically and pretty much instantly, so no need to worry about that.
If you want, you can also preview your website by editing your hosts file:
admin…this is what i have done…created website on wordpress with a wordpress domain…transferred files and sql using firezilla to infinityfree. when i opened an account with infinityfree i chose a new domain name ending rf.gd - i have added this as a subdomain but i think the problem is that i am not using the wordpress domain - si or no? yo no se. gracias
i understand it is neccesary to wait up unti 3 days but i want to make sure they i have completed the process correctly beforehand. gracias
I see a directory listing page on your site. That means that there are no files, or they are in the wrong spot. Please make sure your files are uploaded within the /htdocs folder of your domain.
Thanks
thanks for your support - iam struggling with these files i think i have put them into firezilla again now its still directory but showing the wordpress url too
muchos gracias y tambien si puedes hacer mas
thankyou for your help -
so to be clear i have now reloaded the files inot filezilla casadelosbates.rg into the hdocs - the file is showing and this file is a zip wordpress casadelosbates.wordpress…if this correct - muy bien - pero no - then what do i do - ia msorry for these problems thankyou for your help, muchas gracias
This. Please note that this is the folder casadelosbatesforsale.rf.gd/htdocs/ for your domain right now. Your files are in the main htdocs folder, which doesn’t have a domain assigned to it right now.
Buenas Dias, im really sorry but could you check if i have done this correctly now, I think i have put the files in the right place the directory page on casadelosbates.rg is showing wordpressfile but not webpage, lo siento y gracias
i just cannot seem to put the files into the right place in the hdoc - i dont know why
vale - i think i hvae done it the infinityfree control panel is showing the domain name is ion use with the wordpressfiles - however the webpage is still showing the directory page…gracias
Not quite. I see you’ve uploaded a WordPress XML file. You can just dump that on any hosting account and expect it to work. It’s not WordPress itself, just data for WordPress.
Instead, you can install WordPress on your domain (using Softaculous), and then use the Import feature in WordPress itself to upload your data from your old site to your new WordPress installation.
