Why Wont It Let Me Install A SSL certificate? (urgent pls help)
My InfintyFree domain is not letting me install a ssl certificate
does anyone a fix?
Did you also see that it tells you to
Reset your hosting account password through the Account Settings in the client area
Please try it first.
Did you login to the control panel manually using your hosting username and password? Or did you use the client area control panel button?
If the client area control panel button doesn’t work, then the SSL upload won’t work either. And if you reset the password to the control panel yourself, that’s the reason why it doesn’t work.
If that’s the case, then to fix it, you should indeed:
yep i reseted through control panel so do u have a fix?
k ill try
Owner You are a life saver i fixed ty tysm
