Why Flarum Forum not work in Infinity Free
Blockman Go Forum (000.pe)
Log in and Sign in not work after install on softaculos
Website have free plan
Due to this
Free hosting is using PHP 8.2.
So it will not work here
What’s Forum template work for free hosting plan
Newer versions of Flarum should work on newer versions of PHP.
Do note, that if Softacoulus doesn’t have the newer versions, you will have to install Flarum the manual way, as Infinity Free doesn’t offer a CLI of any kind, including SSH.
Adding a little bit to what @anon54841129 said:
You will have to download the No public path version here, else it won’t work.
