When softaculous abantecart will be updated?
epiz_29508955
When I try to upgrade abantecart itself never works and softaculous still has the old version of abantecart, I need to update the installation to correct bugs caused by a plugin app but the correction is only available for latest software of abantecart and I can’t find a way to upgrade. I need help. Thanks.
Welcome!
Download it from the vendor:
Hello,
Doesn’t works, as I said before, I get any error, usually after I click to upload the file I get:
ERR_CONNECTION_REFUSED
Like the server gets disconnected.
This is why I want softaculous to do the update.
Now after trying again I get this:
This site/page has used all avaialble php / apache processes allowed on free hosting account.
Refreshing the page once the amount of apache / php processes are reduced will cause the site to work
We would recommend upgrading your hosting account at IFastNet Premium hosting accounts , premium hosting accounts have MUCH higher resources dedicated to them.
So we can’t upgrade an installation that the own host supports, I don’t understand
That message appears when you temporarily overload the server. Refresh your website every 15 seconds or so, eventually it will disappear.
Most likely, you got that because the installation script was trying to do too mush at one.
Nope, I left it alone, when I try again, I get one error or the other, apparently the script is blocked by the restrictions, so I can’t update abantecart.
