What is this problem solution?
routine.kesug.com
Unable to determine directory status
An error occurred while trying to check the directory of your website.
what is this problem solution
i opened file manager but i cant did anythink
i Cant upload anythink
You could try going to the control panel, as this can fix some issues. But this sometimes happens, as long as you’re site is working I wouldn’t worry too much
thank you i fix problem
