When visiting posts, i get some wierd errors
Also, visiting the homepage of the forum, i got this error…
Maybe try using private mode or a VPN?
i am using incognito…
Maybe try a VPN? Sometimes private mode does cache…
i can’t vpn - school wifi
Ah, maybe teh WiFi is the issue? O something the school district out in place to block you? I’m going to assume you cannot clear cache and cookies…
that i can…
I have seen it several times so far
it usually happens if you are in the middle of a discourse upgrade
or some similar actions on the server itself where the forum is.
A few refresh and everything will be fine
ok
