Website stopped working properly and admin part as well
I had this message for a couple of months: Your domain name is not pointing to our server!
Your domain name is pointing to the IP address(es): 82.163.176.119. If this issue persists for more than a few hours, please contact support.
Now I wanted to make changes and found out that i cant go to admin wordpress Error establishing a database connection, some pages on website stopped working as well https://chicagotennisfamily.com/us-open same mistake error establishing database connection.
Any ideas how to make it work? Or how to connect support?
Your account’s website IP is 185.27.134.113, but the message says your domain points to 82.163.176.119. That’s a different address, so the domain isn’t pointing at your account. It needs fixing wherever your DNS is managed, which is your registrar or DNS provider, not InfinityFree. The members area has a Health Check section for your domain that shows whether the nameservers or A records are wrong. Waiting longer won’t fix a setup problem. This article explains it:
I can’t tell yet whether the database error is related. Could you tell me which database name and which database host your wp-config.php uses? Please don’t post the password. Your account’s MySQL host is sql100, and the database names on it are er, er_new and wp900 after the if0_40160724_ prefix. If the name or host in the file differs from those by even one character, WordPress will give exactly this “Error establishing a database connection” message.
domain is old ore than 1 year old
it is wp900
i checked domain and it says name servers: ns1.infinityfree.com, ns2.infinityfree.com
