Is it the control panel in my infinityfree loging from where I can do this ?
This is all I can see in my ‘domains’ list in my hosting account: if0_34376105
The Control Panel can be accessed on the Client Area (which is the InfinityFree login), by clicking on the hosting account your domain is on (or, if you’re on a different page like in that screenshot, click on “Home”, then follow the next steps) and then clicking the “Control Panel” button. There you’ll find the domain under the “Addon Domains” section. Remove it and add it again, then go back to the Control Panel’s main page by clicking the InfinityFree (or VistaPanel)’s logo and move the website files from htdocs to 3dotsconsultants.com/htdocs through the File Manager or through a FTP client.
For the last step of moving files, I can see contents when I browse to ‘Control Panel → Online File Manager’. Also, ‘3dotsconsultants.com/htdocs’ is empty … Do I need to move files from former to latter ?? How ??
You’ll have to move the files from the normal htdocs to your domain’s htdocs folder. Go to the normal htdocs folder, then select the files and folders you want to move (Ctrl + A to select all), right click and click on “Cut”, then go back a folder by clicking on .., then go to your domain’s folder, then on htdocs and then right click and click on Paste.
Just by checking if it works on your side will do. I checked and all things are fine on my side, but you might need to clear browser cache and DNS cache if you still get the ads page.
