So i have put my website files from my computer to filezilla into my website
but in my files it looks like this
and in the host it looks like pdf files
So what should i do?
Can you send your website link?
mrhenrix.ml
The other one only shows at ingocnito tho
Ok wait i’ll try again
Ok can you check it now?
wait what? I see it in pdf files
Do CTRL+F5, it will fix it
Is there anyway to fix it without doing that?
Its not working for me the “Ctrl+f5”
Are you not able to do CTRL+F5??? Than just clear your cache and cookies
Hold down the control key, and while you are holding that key down tap the F5 key (at the very top). After you tap the F5 key, release both buttons
Okay i’ll try
Nope still not working
What browser are you using? Chrome, Microsoft Edge, etc.
Chrome
Go to chrome://settting and scroll down until you see the option to clear cache and cookies. Tell the browser to clear your cache.
Clear your CloudFlare cache as well
