Website URL - unrobotizeyourself.free.nf
Error Message - Wasn’t possible to stabilish a safe conection with this site. The site send an invalid answer.
The site doesnt Open on Mobile phones only. Returning an error message.
Works fine for me:
From the error message you are getting though, it seems that you are trying to visit the website through HTTPS instead of HTTP. To do that, you need to install an SSL certificate first:
If you’re using free hosting with your own domain or a subdomain, you’ll want to make your website work over HTTPS (SSL). Fortunately, InfinityFree provides all the tools you need to make it so. If you like videos better then text guides, scroll on down to the bottom of this guide.
This guide uses the control panel functions and the Free SSL Certificates tool provided by InfinityFree to get SSL up and running on your site.
This article only applies to custom domains
Free subdomains (like your…
system
Closed
November 16, 2023, 1:10am
4
