Website not accessible on some mobile networks — DNS_PROBE_FINISHED_NXDOMAIN
https://smartcareerhub.page.gd/home.php
This site can’t be reached.
My website is hosted on InfinityFree using the free subdomain smartcareerhub.page.gd.
The website does not open on several mobile phones when using their default DNS settings. Chrome shows DNS_PROBE_FINISHED_NXDOMAIN.
When Private DNS is set to dns.google, the website opens.
I tested the domain using Google DNS (8.8.8.8) and Cloudflare DNS (1.1.1.1). Both return the IP address 185.27.134.60.
Could you please investigate this DNS issue and advise how to make the website accessible across different mobile networks without requiring visitors to change their Private DNS settings?
Which mobile networks or carriers are the affected phones on? And can you run these two commands on one of them, for example in a terminal app, and post both outputs?
nslookup smartcareerhub.page.gd
nslookup smartcareerhub.page.gd 8.8.8.8
Your tests show that Google and Cloudflare DNS return 185.27.134.60, while the phones’ default resolver answers “this name doesn’t exist”. The first command’s output shows which resolver gave that answer and what it said. That’s what lets someone work out whether it’s one carrier’s DNS or something else. I couldn’t find an answer on the forum that covers this.
Thank you for the response.
I tested the domain on three mobile phones, but the website did not open with their default DNS settings. It opens when Private DNS is set to dns.google.
On my Windows PC, both commands return the same IP address, 185.27.134.60:
I also tested Cloudflare DNS:
nslookup smartcareerhub.page.gd 1.1.1.1
It also returns 185.27.134.60.
I will confirm the affected mobile carriers and share the default DNS results if needed. Could you please advise how to check which DNS resolver is causing the issue on the phones?
Thank you for your response.
All three affected mobile phones were using Jio mobile data. The website does not open with the default DNS settings and shows DNS_PROBE_FINISHED_NXDOMAIN.
When Private DNS is changed to dns.google, the website opens.
On my Windows PC, Google DNS (8.8.8.8) and Cloudflare DNS (1.1.1.1) both resolve smartcareerhub.page.gd to 185.27.134.60.
Could you please help investigate whether Jio’s default DNS is failing to resolve this free subdomain?
Website: https://smartcareerhub.page.gd/home.php
There hare been more reports like this from Jio customers recently, and it’s pretty clear that Jio is blocking some of our domains through their DNS resolvers.
Unfortunately, this block is performed on the Jio side, not by us, so there is not much we can do to fix this issue from our end. You’ll have to take this up with Jio.
Works for me, it’s probably Jio’s DNS blocking some domains.
