Website "low poly"
https://thedev.gq/
I’ve build my website using ftp, I’ve uploaded 3 times on mobirise website and it looked normal, but when I uploaded on the host, it looks like this:
I’ve already deleted the cache/cookies.
CSS/JS is broken. Some resources might be lacking.
popper.min.js:1 Uncaught SyntaxError: Unexpected token '<'
bootstrap.min.js:1 Uncaught SyntaxError: Unexpected token '<'
facebook-script.js:1 Uncaught SyntaxError: Unexpected token '<'
tether.min.js:1 Uncaught SyntaxError: Unexpected token '<'
smooth-scroll.js:1 Uncaught SyntaxError: Unexpected token '<'
nav-dropdown.js:1 Uncaught SyntaxError: Unexpected token '<'
navbar-dropdown.js:1 Uncaught SyntaxError: Unexpected token '<'
jquery.touch-swipe.min.js:1 Uncaught SyntaxError: Unexpected token '<'
script.js:1116 Uncaught ReferenceError: jQuery is not defined
    at script.js:1116
sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52 Invalid App Id: Must be a number or numeric string representing the application id.
b @ sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52
sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52 domReady
sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52 The "fb-root" div has not been created, auto-creating
sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52 XFBML Parsing Start 1
sdk.js?hash=9c6650e190217ff722c4bd0ff7375444&ua=modern_es6:52 XFBML Parsing Finish 1, 0 tags found
VM30:499 Using Translate V3 APIs
VM30:495 Beginning page translation...
VM30:289 edge Translation started
translateInternal @ VM30:289
VM30:500 Took 1650.069999974221 ms to first complete.
VM30:495 Intermidiate complete called with false
VM30:495 Successfully completed translation.```
This is the console log.
It’s quite weird that the security system page appears instead of the js/css files. That’s why you’re seeing <
I’m getting a lot of 404 errors, which means some of your resources have been misplaced
Please make sure to upload the assets folder as well. Neglecting to upload that is a common error with Mobirise.
Well, I’ll try to save in another folder on my pc, then upload it into IF server
