This site can’t be reached
mist.ct.ws’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE
its not running on my website. it used to run on my website from the day i created it but from 1 week its not running..can u please look up in my website ..whats wrong ? or the subdomain is down?
Could you run the check on dnschecker.org and tell me what it shows? Enter mist.ct.ws with record type A. Also tell me which internet provider and country you’re on. That separates a problem with the domain, which would affect everyone, from your network giving your browser the wrong answer, which would affect only you.
Your hosting account is active and mist.ct.ws is listed on it. A free subdomain has nothing for you to set up, so the cause is probably not your account. The article on this error says that if most locations show a red cross, the problem is with the domain. If most show an IP address, the problem is on your side. Some networks and providers filter free subdomains by returning “not found” for them.
If dnschecker shows it working, please also run these two commands in Command Prompt or Terminal and post the output:
DNS request timed out.
timeout was 2 seconds.
*** Request to UnKnown timed-out
A lot of sub domains are down right now. I doubt it will last too long, but it is Sunday 1st day of the month as well, a lot of folks do maintenance on Sunday.
