Hey,
This is Sajid Biswas. My hosting account is epiz_21325898. I have built the website. It is http://www.technosajid.in/ .
Its opening from computer easily, but not opening from some android browser like opera mini. kindly give me solution.
Thank you.
@SajidBiswas Everything is fine here. Techno Sajid is loading smoothly here. Try clearing the cookie or reinstalling Opera or UC mini.
@Ranakhas Thank you so much
@Ranakhas this problem is solved. but sometimes my site redirects to ‘Enable or disable cookies’ page ( Turn cookies on or off - Computer - Google Account Help ) - screenshoot ( https://drive.google.com/open?id=1yvH74QURmwqb4xpZqnzLgLnHMIPRvfIF )
@SajidBiswas it is a cookie test represented as i if the value of i increase more than 3 then it redirect to Google knowledge base that How to enable/disable cookie it only occurr when you failed to proof that you are not a bot
@Ranakhas then how to prove that i am not a bot? I want to stop this disgusting thing. Its happening both the time- on modifying my website and visiting my website!
Clear the cookie and enable the cookie, in simple clear the data of your browser and enable cookie then visit your site @SajidBiswas
@Ranakhas thank you but i have already done these all! but no result
Sajid Bhai WordPress install Kiya Hai Kiya??
Please ensure cookies and Javascript are enabled in your browser.
@Ranakhas ha vai
@Admin sir I have enabled these
@SajidBiswas Yeh problem mujay be the toh mai nay sitebuilder delete kar kay phir say wordpress install kiya app be kar lay! Data Backup kar lay aur phir import kar lena aghar itna muskail kam hai toh blogger pay ajaye woh asaan hai aur ab toh free ssl be hai blogger pay for custom domain!
mai sob kuch design kar chuka hu. avi change nehi kar sakta. aap visit kar ke dekhiye ek bar
@SajidBiswas I visited many times it provides slow user experience on mobile try using AMP plugin which may also increase your website SEO rank.
For more at seotoolcity.com
@Ranakhas is it slow? why? how to resolve it?
@SajidBiswas use thishttps://developers.google.com/speed/pagespeed/insights/ to check your website speed and answer of your questions that how to solve the problem.
@Ranakhas waooo. thank you
There are many such tools.
For Keywords suggestion try https://www.keyword.io/ now they added support for wikipedia and yandex also the best tool to boost traffic
