shatteredgame.ca Is having connection problems even though my domain is setup correctly
No error messages
I try to go to my website but it is down for me or when I refresh It says it can’t connect on my browser.
No error messages
Bro
shatteredgame.ca
This domain does not exists,
Welcome to the Community!
Domain is registered
Domain Name: shatteredgame.ca
Registry Domain ID: 83708958-CIRA
Registrar WHOIS Server: whois.ca.fury.ca
Registrar URL: https://whc.ca
Updated Date: 2020-08-15T22:38:57Z
Creation Date: 2020-08-15T21:54:31Z
Registry Expiry Date: 2021-08-15T21:54:31Z
Registrar: Web Hosting Canada (7081936 Canada Inc.)
Registrar IANA ID:
Registrar Abuse Contact Email:
Registrar Abuse Contact Phone:
Domain Status: clientTransferProhibited EPP Status Codes | What Do They Mean, and Why Should I Know? - ICANN
Domain Status: serverTransferProhibited EPP Status Codes | What Do They Mean, and Why Should I Know? - ICANN
Registry Registrant ID: REDACTED FOR PRIVACY
Registrant Name: REDACTED FOR PRIVACY
Registrant Organization: REDACTED FOR PRIVACY
Registrant Street: REDACTED FOR PRIVACY
Registrant City: REDACTED FOR PRIVACY
Registrant State/Province: AB
Registrant Postal Code: REDACTED FOR PRIVACY
Registrant Country: REDACTED FOR PRIVACY
Registrant Phone: REDACTED FOR PRIVACY
Registrant Phone Ext: REDACTED FOR PRIVACY
Registrant Fax: REDACTED FOR PRIVACY
Registrant Fax Ext: REDACTED FOR PRIVACY
Registrant Email: Please ask the Registrar of Record identified in this output for information on how to contact the Registrant, Admin, or Other contacts of the queried domain name
Registry Admin ID: REDACTED FOR PRIVACY
Billing Email: Please ask the Registrar of Record identified in this output for information on how to contact the Registrant, Admin, or Other contacts of the queried domain name
Noice. From where did you find this?
I think my website whoishostingthis provides wrong information.
It’s not expired and it does exist, It worked fine before atleast
It hasn’t propagated properly: DNS Checker - DNS Check Propagation Tool
Wait up to 72 hours.
Or you can try re-submit the nameservers on your domain panel.
Also, You should use lookup.icann.org if your not sure, as it gives me the following:
Dates
It is ran by the Internet Corporation of Names and Numbers or ICANN, who monitor domain names and IP assigned addresses. It is the most accurate whois server you can get, even though WHOIS Servers are ran by the TLD holder… Story for another day
Well, It started August 25th… I’ll try re-submitting it and if that doesn’t work I’ll contact my domain provider.
The weird thing is I can’t connect from my PC but I can connect on my iPad, and if I refresh the website it loses connection but as soon as I retype the domain, It reconnects!
It usually happen to a newly bought domain. Take really long propagation.
I ever experienced it, too.
& I usually revert the nameserver to default nameserver of domain provider, then change back to my hosting nameserver. Repeat it up to 3-5 times. ![]()
From this i think his nameservers has been propagated.
The site you use check for domain ip address if it doesn’t pointing to anything than that error you see will be generated there.
He shared whois records of domain.
Oh now you had removed NS i think
CNAME shatteredgame.ca shatteredgame.ca.cdn.cloudflare.net 24 hrs
I only found this in your dns records and no nameserver.
