Your domain name is not pointing to our server!
Your domain name is pointing to the IP address(es): 185.27.134.142. If this issue persists for more than a few hours, please contact support.
Google flags this website as unsafe
Google Safe Browsing lists this website for phishing or deceptive content. Visitors see a warning before they can open it. Remove the harmful content and request a review from Google.
The website has been down since last week but for reaganvisuals.rf.gd works please assist immediately
The IP in that error, 185.27.134.142, is the address of one of your older hosting accounts, the one that has since been deleted. Your domain is now on a newer account with a different IP, 185.27.134.212. So the domain’s DNS looks like it’s still pointing at the old server, which is why the rf.gd address works and the .co.ke one doesn’t.
Our article on domain setup says the members area checks this for you in the Health Check section for your domain. It shows whether your nameservers point to us and, if they don’t, whether your DNS records point to the right IP address. The settings themselves are managed at your domain registrar or DNS provider, not with us, so any fix is made there. The article also says a change can take up to 72 hours to work everywhere.
Are you using InfinityFree’s nameservers for the domain, or A records at your registrar? That decides where the old IP is coming from. If it’s an A record, it needs changing to the current IP.
The Google warning is a separate problem. Google Safe Browsing lists the site for phishing or deceptive content, and only Google can remove that listing, after you request a review in Search Console. This article explains the likely causes and the steps:
