Hi, from 2 hours my site do not work.
www.webtv.great-site.net
have any idea?
thankx
error message
This site can’t be reached
webtv.great-site.net refused to connect.
Try:
- Checking the connection
ERR_CONNECTION_REFUSED
have any idea?
thankx
error message
Try:
Do you use Cloudflare, and are your nameservers setup correctly?
my site is up from 2 months
So your website worked before, and just recently started to return this error?
i do not use cloudflare
yes , i checked 10 min ago and was down
Can you check your control panel and see if there any ary error messages, or if any of the metrics on the right are at or near 100%?
Thanks.
everything seems to be ok on control panel,msql…etc
i just wanted to make update to my site ,but i realized is down.but i do not maked any changes
so…i think the problem is temporary.
can you go to your domain provider, and take a screenshot of the nameservers you are using?
Sorry, didn’t realize I can do this myself
You are using the wrong nameservers, change these to ns1.epizy.com and ns2.epizy.com. This may be one of the things causing the issue.
I am confused. Try changing your nameservers to ns1.epizy.com and ns2.epizy.com in your namecheap dashboard
maybe ,becouse i tryed to get ssl(https)?
You can get SSL for free with InfinityFree, but you have to be using the correct nameservers first. (ns1.epizy.com & ns2.epizy.com)
I’m going to ask again:
Is your website also using host nwfrxbce.epizy.com aka 185.27.134.217?
I think there is an outage with this web server right now.
i do not find in dashboard where to change nameservers.pls hlp
Actually, I think your issue is here…
You need to assign your domain to an account.
