bakeryprod.free.nf
This site can’t be reached
bakeryprod.free.nf’s DNS address could not be found. Diagnosing the problem.
DNS_PROBE_POSSIBLE
I also experienced this on the html-5.me domain, it shows the exact same error, just the different url. I checked my account it said active. And I think they didn’t suspend my Hosting Account because I’ve had a lot is visitors in my website every month.
Yeah same here to with my page.gd domain. But yesterday it work fine today cannot be open anymore
I’m experiencing the exact same issue with my freehosting.dev domain. My site was working fine a few hours ago, but now it fails to load completely.
Is anyone else on freehosting.dev running into this right now?
Nameservers are DOWN!
From my own uptime monitor
This is a global issue, no need for more “I have this issue too” posts
any suggestion for change server ?
If you have a custom domain you can use your own DNS provider e.g. Cloudflare and point an A record to the IP Address in your Client Area. (Whether it’s worth the effort to do this it’s on you)
If you are on a free subdomain, you will have to wait it out unfortunately
Edit: typo
yes ,same problem for me also all my websites are same problem
thanks spooky
I got more info, Free Hosting Nameservers are actually hosted on FranTech/NameCrane/BuyVM where they had a power outage. This is not something iFastNet can fix directly unless they move stuff back to their own infra.
NameCrane is aware of this and is actively trying to fix it
FranTech Discord:
Yes me too, it was working an hour ago then it suddenly went:
Check if there is a typo in
If spelling is correct, [try running Windows Network Diagnostics](javascript:diagnoseErrors()).
DNS_PROBE_FINISHED_NXDOMAIN
Thanks everyone who helped to track down the cause. I posted the issue on the status page as well.
All back up around 05:30 UTC+8
NS just went down again, a bunch of KVM machines on FranTech went down too, seems to be network issues
Edit: back after a couple of minutes
Yes, there was another blip between 9:55 and 10:05 UTC. Probably still having trouble getting everything back online.
They say their servers didn’t like yesterday’s multiple power cycles
I’m having the same problem with my pages.
What problem on which pages?
And what’s the DNS error you see on that page?
