The article below covers this error. It says the block is either your device, your network or provider, or the server blocking your IP address, and that a few quick tests tell them apart.
The detail I need first is whether the other devices where it works are on the same network as the computer that fails. If a phone on the same Wi-Fi opens the site, the problem is on your computer, such as antivirus, a firewall or an extension. If it fails on every device on that network and only works over a VPN or mobile data, the block is tied to your network or IP address.
The article describes two tests that would help:
Type the address with http:// instead of https://. If HTTP opens and HTTPS times out, the article says the cause is almost certainly your network or provider. A block on the hosting servers applies to both.
Run the Globalping test from your provider’s network. If other customers of your provider can reach the site, the server is most likely blocking your IP address. If they fail too, it’s your provider.
The article also says server-side IP blocks usually expire on their own within 24 hours. If your router gives you a new IP address after being off for a few minutes, that’s a quick test too.
Here’s the full article, with all the steps:
Can you tell me what you get from the http:// test, and whether the working devices share your network?
