Website cache not clearing
No you can’t. Thanks. But this answer helped you.
I now realise what has happened and so I will post it on the forums in case any one else runs into similar problems.
First of all make sure you’ve done the following things:
  1. Cleared cache
  2. Flushed DNS using cmd: ipconfig/ flushdns
  3. Cleared Cloudflare cache
  4. Restarted computer
If you’ve switched hosting providers and it still doesn’t work:
Usually when you change the nameservers of your domain, you will have to wait 24hrs (unless you use a service like Cloudflare). But some network providers do something called DNS cache. This means that your computer or your Internet Service provider stores the DNS lookup of websites you’ve visited, temporarily. With most ISP step 2 would have worked. However, some ISP providers still store it until they update TTL which is in most cases 24hrs. Until then, you will be stuck with you’re old hosting provider.
What to do while that:
Use a different IP address or use VPN. Many are available at the chrome web store for free. The VPN I use is this one and I also used this WebRTC.
Hope it helps!
