I made a free website with infinityfree but upgraded my account to ifastnet and I think that is where it all went wrong.
I want to be able to use a site builder but can’t figure out how to upgrade or who to upgrade with so that I can continue to use the site builder I have been using and maintain the website I have just built and published. Is it ifastnet, infinityfree, or site.pro?
Any help or advice would be greatly appreciated. Thank you.
Do you just want good quality, fully featured web hosting and are you hosting anything EXCEPT Site.Pro? Then iFastNet is a great pick.
Do you have a Site.Pro site and want to upgrade? Then buy hosting from Site.Pro.
Do you want to upgrade but not really upgrade at all, and definitely not spend money? Then “upgrade” with InfinityFree. Because we don’t sell any upgrades.
And I would appreciate it if you actually considered the help and advice I already gave you.
Actually all premium servers ip addresses are liscensed for site.pro, after moving your site over though the license needs to be updated, running in the cPanel ‘Terminal’ .
cd [BUILDER _DIR] && /opt/alt/php82/usr/bin/php index.php /api/update-builder
Then the site.pro builder will be license to the correct site.pro account and work.
Thank you so much for replying. I feel like this is good info and advice but I think I’ve come to the conclusion that it is all beyond me. I’m an old fuddy duddy.
Thanks again.
