Warning and Fatal Error
Warning : require(/home/vol5_5/epizy.com/epiz_29358003/htdocs/laravel/vendor/composer/autoload_static.php): failed to open stream: No such file or directory in /home/vol5_5/epizy.com/epiz_29358003/htdocs/laravel/vendor/composer/autoload_real.php on line 33
Fatal error : require(): Failed opening required ‘/home/vol5_5/epizy.com/epiz_29358003/htdocs/laravel/vendor/composer/autoload_static.php’ (include_path=‘.:/usr/share/pear/’) in /home/vol5_5/epizy.com/epiz_29358003/htdocs/laravel/vendor/composer/autoload_real.php on line 33
Im getting this error, how to fix this?
Per the topic template, please provide a domain.
It says the file could not be found. So just upload the missing files and/or directories?
If you want more help, we need more information. Please tell us your domain name, the name of the software you’re trying to install and what you’ve done to install it.
