When I try to get my SSL certificate for free the website gives me this error.
https://www.instantssl.com/free-ssl-certificate.html → A Trial Certificate has already been issued for this domain name - please contact Support!
So what can I do with that?
Here is the picture : https://hizliresim.com/NnkQnP
you probably use one of the free subdomains
more precisely subdomain like yourwebsite.epizy.com
so you can “not” get a certificate for several reasons…
basically you need a domain not subdomain
how to get a free domain? here Freenom - A Name for Everyone
then use cloudflare because it gives you free ssl (https) plus other stuff
https://www.cloudflare.com/
see this
also read this https://infinityfree.net/support/add-your-own-domain/
If a certificate issues won’t issue a certificate to you, please contact them. We don’t control InstantSSL and can somehow give you an InstantSSL certificate when InstantSSL won’t let you.
Thank you sir but any of them does not work i found the cloud flare as you mentioned. However I dont know how to change name server can you help me?OxyDac said:you probably use one of the free subdomains
more precisely subdomain like yourwebsite.epizy.comso you can "not" get a certificate for several reasons...basically you need a domain not subdomain
how to get a free domain? here https://www.freenom.com/en/index.html?lang=en
https://www.cloudflare.com/see thishttps://www.youtube.com/watch?v=l0Q1CiJWvo8
Changing nameservers is done through the panel of your domain registrar. It’s not possible to change the nameservers (or use Cloudflare, or get trial SSL certificates) of a free subdomain.
