This could be due to already adding the domain to this or another account or, you have not changed the nameservers as required or not enough time has passed since changing the nameservers..
Remember, you need to change the nameservers on a domain via registrar control panel BEFORE adding it to your account, it may take 24~72 hours to completely update the nameservers.:
Please verify your nameservers and/or change them to:
(The nameservers are changed via your domain registrar control panel, NOT your hosting control panel.)
ns1…
After changing the nameservers you may have to wait 24~72 hours prior to being able to add the domain to your account..
Once the name servers are set it may take upto 76 hours before the domain can be added here.
Name servers MUST be set before adding the domain here, if your registrar REQUIRES that you add a domain before setting the name servers then you will need to use a different domain name / registrar (or contact there support requesting they manually set the name servers). We are NOT able to add domains to the vPanel without the name servers being set firstly.
I tried to set up a dynv6.com zone as a domain. Not even sure if this is possible, I have never done that with dynv6. According to a tutorial I found here in the forums, I added a cname record from the error message of the cpanel to my dynv6 zone. That’s all. Then I tried adding the domain in the cpanel using the dynv6 domain name. It still gives the same error message as if the cname record wasn’t found.
Can someone help? I’ve never done this before.
