epiz_30219194
The uploaded file exceeds the upload_max_filesize directive in php.ini.
I get this error when i try to upload a theme or a plugin from zip
epiz_30219194
If theme or plugin is more than 10mb, it is better to extract files locally then upload via ftp
idk how to do that
Unzip the file on your computer, then upload the resulting folder to your website.
i tried it,but it resulted a serial error on wordpress
Not if you do it correctly. Unzip the file on your computer, and upload the folder to the “Plugins” folder using FTP.
yeah, i did the same, with filezilla.
it works finally!! tysm
