file manager and ftp(please specify the URL of the site on which you are experiencing the problem)
404 on file manager, and 0x80044450 when using ftp
niether file manager or ftp will allow me to upload more photos though i have 4gb free in my account. using file manager i have tried upload via folder and individually and nothing.
KangJL
August 5, 2025, 4:43am
2
Please provide ftp logs
When trying to debug issues with FTP connections, it’s very useful to know what an FTP client is doing under the hood. FileZilla is a very popular FTP client which can provide fairly detailed information about it’s connections.
This article explains how to get this information.
Enable debug logging
To enable debug logging in FileZilla, you’ll need to do the following:
Go to Edit → Settings…
Scroll down to the Debug page.
Ensure that “Show debug menu” is enabled (it is by default).
Update the…
Also, make sure you did not exceed inode limit
Your control panel shows an inode counter that tracks how many files and folders you have on your hosting account. If you’re seeing high inode usage or approaching the limit, don’t panic. Most websites use many inodes, and this is completely normal.
Should I be worried about my inode usage?
For most websites, high inode usage is expected and not a problem:
Normal usage: 40-60% of your inode limit is typical for websites with WordPress, plugins, themes, or multiple sites. Large software install…
Admin
August 5, 2025, 8:18am
3
sniperwil:
404 on file manager
The file manager can be a bit finicky, especially with more complicated tasks like uploading many files. What exactly are you trying to do with it?
Googling that error code tells me you’re using SmartFTP, and SmartFTP says there is an issue with your credentials.
Did you already check this article?
Being able to access your hosting account over FTP is very important to manage your website files. However, there are reason why you may have trouble connecting to the FTP service. This article explains a few things you can try to fix your FTP connection.
Login to your control panel
After your account has been created, or reactivated after a suspension, you may need to login to the hosting control panel once to enable FTP access to your account.
You can login to the control panel by logging in…
There are limits on how big the files can be you are attempting to upload, double-check if the size is great, but as admin said, there seems to be an issue with your credentials, so check again if the correct ftp details were entered, or check the article admin provided
Thanks for inputs, I found the answer. My computer was buggy, misrepresenting the file sizes for some of the images.
