Upload Corrupting .png Images
epiz_29635767 // leksoconsulting.com
Website not showing .png images properly, shows the placeholder icon alone
So I have finished testing the main page / preloader in XAMPP, everything was working fine … then I uploaded the .png images to htdocs using WinSCP - tried the website and the placeholder images showed up. I thought maybe the actual paths have to be a bit different, tried that - no go … downloaded all the files back to my PC, tested in XAMPP … same issue now migrated … was playing around with it for a while until I tried opening the images and the image viewer complained about not supporting this format. Upload to the Server seems to have broken them .png files.
I have tried uploading using the built in File Manager @ infinityfree, same result … images can no longer be open … very weird. This is more of a solution post rather than a request since I could not find any solutions on the forum, I tried to rename the IMG locally on the server by removing the .png extension … modified the without the .png extension only for one of the images and interestingly enough they all started working … almost as if the server started to recognize them after the first image loaded … very strange, not sure if I’ll be able to reproduce it but I can try with my other account :slight_smile:
Please let me know if you would like me to try it out or if you will try this test yourself :slight_smile:
Cheers !!!
All four images are working for me. Please try clearing your cache.
Hello, yes they are working now. As I mentioned I had to rename them (remove and add back the .png extension) ON the Server after uploading them to make them work :slight_smile:
But on first upload they would show as broken and when you try to open them with a Viewer there would be a message saying that “the format is not supported”
I’ll try to reproduce with the other account and post some feedback
