i have a problem with gsc the sitemaps Unable to read sitemap i contacted rankmath support
and they said to contact the hosting provider
( I searched all the formes)
full error incorrect http header content-type: “text/html” (expected: “application/xml”)
Hi lmsversa,
Their attempt to pull sitemaps has been blocked by this security system on free hosting.
Read more about it here.
Don’t worry, this is normal! When you visit your website, you might notice ?i=1 added to the end of your URL. Here’s what’s happening and why.
What is the ?i=1 suffix?
The ?i=1 is a security check that protects your website from bots and malicious traffic. Our system needs to verify you’re using a real web browser before letting you access your site.
Why does it appear?
When you first visit your website, our security system:
Sends a small test to your browser
Checks if your browser can store…
Cheers!
so what should I do?
go to another hosting
Feel free to do so. We are not threatened.
We know that. I’m not going to recommend other hosts (for obvious reasons), but good luck to you
Admin
April 20, 2024, 10:34am
7
Please note that we have taken special precautions to make sure that search engine crawlers can access your site. So even though a sitemap validator will not be able to access your site, Google itself will be completely unaffected by this.
InfinityFree is a website hosting service. That means that the hosting accounts we provided are intended for hosting websites. Websites contain pages that are accessed through web browsers. InfinityFree is not intended to be used for file sharing, API hosting, database hosting or background tasks/tools.
To help enforce this, free hosting enforces a security system that makes sure that anyone trying to access your website is using a normal web browser. This is done by checking whether the web br…
