Unable to reach subdomain (using BlueHost)
Website | Account
seanmcginty.space | epiz_27703225
This site can’t be reached
dinrah.seanmcginty.space’s server IP address could not be found.
Try:
  • Checking the connection
  • Checking the proxy, firewall and DNS configuration
  • Running Windows Network Diagnostics
ERR_NAME_NOT_RESOLVED
I am using BlueHost as a domain provider, and have pointed the nameservers to ns1.epizy.com / ns2.epizy.com. I created a subdomain in the cpanel named dinrah.seanmcginty.space and have tried viewing this in my browser, though I recieve the following error above. I set up an Address Record in the BlueHost panel and pointed the subdomain to 185.27.134.204 which is the IP Address for this account.
Hello Your sites are working for me Also Kindly wait upto 72hrs to Make work your domain everywhere
Hope this helped you!
Cheers!
I’ll try it again in 72 hours and see if it still has an issue.
P.S. The main site seanmcginty.space works fine, I have only had the issue on the subdomain dinrah.seanmcginty.space.
Is That Should be Like this?
Hmm, ok seems to be on my end.
I’ll wait for a bit.
Thank you very much for the help! :innocent: :sweat_smile:
Glad I helped you! Happy Hosting!
