Unable to make https work for subdomain
subdomain.xyzsecurity.xyz
his site can’t provide a secure connection
subdomain.xyzsecurity.xyz sent an invalid response.
  • [Try running Windows Network Diagnostics](javascript:diagnoseErrors()).
ERR_SSL_PROTOCOL_ERROR
I am trying to use one of infinityfree free SSL certificates. I managed to make it work for the main domain (xyzsecurity.xyz) but did not manage to do it for my subdomain (my subdomain is called subdomain.xyzsecurity.xyz). I tried two different type of SSL certificates but still no success. I am attaching the cname screenshot for your reference. Any help is highly appreciated
So did you install SSL certificate for this domain in the control panel?
Hi jaikrishna.t
Thank you for your reply. Does this answer your question or there is soemthing else that you meant?
Make sure you do this
and this
That did the trick. Many thanks mate
