I mistakenly installed two SSL certificates on the same domain “https://deliverytrue.store”, the first is Let’s Encrypt and the second is GoGetSSL, and now I can’t access the site anymore, I get “We couldn’t find that page.
404”. Can you help me?
You can’t install more than one certificates at the same time, the previous one will get overridden.
Also, your site is working fine for me, I see a new WordPress installation. The /admin path the not working because it does not exsist. It should be /WP-admin
I used softaculous, automatic installation… I already installed wordpress with this procedure and it worked… later, to try to solve some SSL problems, I deleted the site and reinstalled and now I don’t see the login panel anymore… it gives me the code 404
